Kingston HyperX CloudX Ear Pads Replacement
  1. Kingston HyperX CloudX Ear Pads Replacement, Ear Pads: step 1, image 1 of 1
    • Place one finger on the inside of the cushion and place the other finger on the outer rim of the ear pad cushion.
    • Gently pull the ear pad away from the headset, removing the flap from the groove until the old ear pads are fully detached.
  2. Kingston HyperX CloudX Ear Pads Replacement: step 2, image 1 of 1
    • Take the new ear pad and slide the top side of the flap into the groove of the ear cup.
    • Once the flap is inside the groove, slide it all the way in to make sure the flap is secured inside the groove.
  3. Kingston HyperX CloudX Ear Pads Replacement: step 3, image 1 of 1
    • Squeeze the top part of the cushion into the earcup to keep it secure and prevent the flap from sliding out of the groove.
    • Make sure to keep a tight squeeze onto the cushion until it is fully secured onto the earcup to prevent the flap from slipping out.
  4. Kingston HyperX CloudX Ear Pads Replacement: step 4, image 1 of 1
    • Slowly start going around the outside of the earcup and stretching the cushion so that the flap is secured into the groove.
  5. Kingston HyperX CloudX Ear Pads Replacement: step 5, image 1 of 2 Kingston HyperX CloudX Ear Pads Replacement: step 5, image 2 of 2
    • Push the flap further into the groove by taking a spudger and going around the outside of the headset slowly pushing the spudger into the groove to make sure the flap is fully secured into the groove.
    • If you do not have a spudger, you can also use a credit card instead.
  6. Kingston HyperX CloudX Ear Pads Replacement: step 6, image 1 of 1
    • Squeeze the ear cushion and move it slightly back and forth to ensure the flap is secured.
    • Repeat on the other side.
Finish Line
Sam Bloch
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 49
All Time: 498
