Kirby G5 Vacuum Belt Replacement
  1. Kirby G5 Vacuum Belt Replacement, Vacuum Belt: step 1, image 1 of 1
    • Place the vacuum at an angle most comfortable and easy to access with the bottom facing upwards.
  2. Kirby G5 Vacuum Belt Replacement: step 2, image 1 of 2 Kirby G5 Vacuum Belt Replacement: step 2, image 2 of 2
    • Remove the three screws holding the base plate to the body of the vacuum using a flat head screwdriver.
    • Place the plate to the side.
  3. Kirby G5 Vacuum Belt Replacement: step 3, image 1 of 1
    • Simply slide the roller out of the vacuum.
    • The belt is attached to the roller on either side.
  4. Kirby G5 Vacuum Belt Replacement: step 4, image 1 of 2 Kirby G5 Vacuum Belt Replacement: step 4, image 2 of 2
    • Slide the vacuum belt out from beneath the wheel holding it in place.
  5. Kirby G5 Vacuum Belt Replacement: step 5, image 1 of 1
    • Insert your new belt and pop the roller back into place.
  6. Kirby G5 Vacuum Belt Replacement: step 6, image 1 of 2 Kirby G5 Vacuum Belt Replacement: step 6, image 2 of 2
    • Secure the plate once again until it clicks into the made grooves.
    • Secure the three screws until tightened.
Make sure to test the vacuum and securely tighten all screws. With that, you’re good to go!
Gina Trojano
157 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 61
All Time: 1,088
