KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Internal Bowl-Lift Arm Adjusting Bracket Repla
    • Before starting ANY repair/disassembly of the mixer, make sure it is fully unplugged from the electrical outlet.
    • While this model is not recommended for commercial use, if the mixer is being used in a commercial environment, a LOTO tag can be affixed via the hole on one of the prongs on the mains plug to prevent accidental activation.
    • The speed/motor control assembly contains capacitors which can retain their charge for an indefinite amount of time. These capacitors can present a significant and potentially fatal shock hazard.
  1. KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Internal Bowl-Lift Arm Adjusting Bracket Repla, Remove the Planetary Assembly: step 2, image 1 of 3 KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Internal Bowl-Lift Arm Adjusting Bracket Repla, Remove the Planetary Assembly: step 2, image 2 of 3 KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Internal Bowl-Lift Arm Adjusting Bracket Repla, Remove the Planetary Assembly: step 2, image 3 of 3
    • Place some dish towels or other soft material in the base to protect it from any potential impact.
    • Disconnect the planetary from the motor drive shaft by removing the retaining pin (circled in yellow). You can do this with a hammer and either a pin punch or a Torx T15 screwdriver. Simply hammer the punch/screwdriver on the pin until it comes out the other side.
    • If the planetary assembly doesn't fall out, you might have to give it a firm pull straight down to remove it.
  2. KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Internal Bowl-Lift Arm Adjusting Bracket Repla, Remove the trim band: step 3, image 1 of 1
    • Using a #2 Philips Screwdriver, remove the screw which holds on the trim band.
    • Remove the trim band.
  3. KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Internal Bowl-Lift Arm Adjusting Bracket Repla, Remove the mixer cover: step 4, image 1 of 3 KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Internal Bowl-Lift Arm Adjusting Bracket Repla, Remove the mixer cover: step 4, image 2 of 3 KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Internal Bowl-Lift Arm Adjusting Bracket Repla, Remove the mixer cover: step 4, image 3 of 3
    • Remove the four screws (circled in yellow, two on each side) using a #2 Philips Screwdriver
    • Remove the cover by lifting it straight up.
  4. KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Internal Bowl-Lift Arm Adjusting Bracket Repla, Remove the Planetary Gear: step 5, image 1 of 3 KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Internal Bowl-Lift Arm Adjusting Bracket Repla, Remove the Planetary Gear: step 5, image 2 of 3 KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Internal Bowl-Lift Arm Adjusting Bracket Repla, Remove the Planetary Gear: step 5, image 3 of 3
    • Using the T25 Torx Screwdriver, remove the four torx screws by the powertrain (circled in yellow, two on each side)
    • When removing the last screw, make sure to place your hand under the planetary gear as it is heavy and will fall out immediately.
  5. KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Internal Bowl-Lift Arm Adjusting Bracket Repla, Disconnect the motor: step 6, image 1 of 3 KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Internal Bowl-Lift Arm Adjusting Bracket Repla, Disconnect the motor: step 6, image 2 of 3 KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Internal Bowl-Lift Arm Adjusting Bracket Repla, Disconnect the motor: step 6, image 3 of 3
    • Remove the hall effect sensor from its mount by pressing down on the tab (circled in yellow in the first picture) and sliding it out.
    • Disconnect the power cable by holding down the clip on the right side of the plug (circled in blue) and pulling the plug straight up.
  6. KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Internal Bowl-Lift Arm Adjusting Bracket Repla, Remove the powertrain/motor: step 7, image 1 of 2 KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Internal Bowl-Lift Arm Adjusting Bracket Repla, Remove the powertrain/motor: step 7, image 2 of 2
    • The powertrain is comprised of the motor, the gearbox, and the transfer gears. Unlike previous generations of KitchenAid AC Motor bowl-lift mixers, which had these broken in to discrete parts, this is a single unit.
    • Using a #2 Philips screwdriver, remove the four screws (circled in yellow, two on each side) attaching the powertrain to the mixer body.
    • Place the powertrain to the side, taking care not to damage any of the plastic parts like the rear fan.
  7. KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Internal Bowl-Lift Arm Adjusting Bracket Repla, Remove the speed/motor control assembly: step 8, image 1 of 3 KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Internal Bowl-Lift Arm Adjusting Bracket Repla, Remove the speed/motor control assembly: step 8, image 2 of 3 KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Internal Bowl-Lift Arm Adjusting Bracket Repla, Remove the speed/motor control assembly: step 8, image 3 of 3
    • Using a #2 Philips screwdriver, remove the two screws (circled in yellow in the first image) holding the speed/motor control assembly to the mixer body.
    • Pivot the assembly up to reveal the power connector (circled in blue in the second image).
    • Disconnect the power connector from the speed/motor control assembly by depressing the tab (circled in green in the third image) and pulling upwards.
    • Set the speed/motor control assembly to the side.
  8. KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Internal Bowl-Lift Arm Adjusting Bracket Repla, Remove the power cord: step 9, image 1 of 1
    • Using a #2 Philips screwdriver, remove the screw (circled in yellow) which attached the ground lead to the mixer body.
    • Remove the power cord by lifting up at the strain relief where it passes into the mixer (circled in blue).
  9. KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Internal Bowl-Lift Arm Adjusting Bracket Repla, Remove the lower gearcase: step 10, image 1 of 2 KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Internal Bowl-Lift Arm Adjusting Bracket Repla, Remove the lower gearcase: step 10, image 2 of 2
    • Now comes the hard part: Using a #3 Phillips Screwdriver, remove the three screws holding down the coverplate and attaching the lower gearcase to the mixer body.
    • These screws are extremely difficult to remove. If you are not strong enough to remove them, an impact screwdriver can be used to remove them.
    • Lift straight up on the lower gearcase to remove it from the alignment pins (circled in blue in the second picture) and expose the bowl-lift mechanism.
    • When reinstalling, make sure these alignment pins are inserted into the lower gearcase correctly and the screws are reinstalled super tight.
  10. KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Internal Bowl-Lift Arm Adjusting Bracket Repla, Replace the Bowl-Lift Arm Adjusting Bracket: step 11, image 1 of 3 KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Internal Bowl-Lift Arm Adjusting Bracket Repla, Replace the Bowl-Lift Arm Adjusting Bracket: step 11, image 2 of 3 KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Internal Bowl-Lift Arm Adjusting Bracket Repla, Replace the Bowl-Lift Arm Adjusting Bracket: step 11, image 3 of 3
    • Using a #1 Phillips Screwdriver, remove the small screw anchoring the Bowl-Lift Arm Adjusting Bracket to the handle.
    • Slide the handle out from the mixer body, as shown in the second picture. Continue sliding the handle out until the Bowl-Lift Arm Adjusting Bracket comes free.
    • Using needle nose pliers, detach the C-clip holding the Bowl-Lift Arm Adjusting Bracket from the Bowl-Lift Rod (circled in green). Then remove the Bowl-Lift Arm Adjusting Bracket by sliding it off the Bowl-Lift Rod.
    • Replace the Bowl-Lift Arm Adjusting Bracket.
If you have difficulty accessing the screw hole for the Bowl-Lift Arm Adjusting Bracket, insert the handle fully into position and rotate the handle until the screw hole aligns with the notch in the Bowl-Lift Arm Adjusting Bracket
PedroDaGr8
2,971 Reputation
15 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 36
All Time: 788
