KitchenAid KHM512ER Eject Button Spring Replacement
  1. KitchenAid KHM512ER Eject Button Spring Replacement, Eject Button Spring: step 1, image 1 of 2 KitchenAid KHM512ER Eject Button Spring Replacement, Eject Button Spring: step 1, image 2 of 2
    • Insert the back of a plastic opening tool into one of the beater holes.
    • Apply force to pull the circular plastic part off.
    • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
  2. KitchenAid KHM512ER Eject Button Spring Replacement: step 2, image 1 of 3 KitchenAid KHM512ER Eject Button Spring Replacement: step 2, image 2 of 3 KitchenAid KHM512ER Eject Button Spring Replacement: step 2, image 3 of 3
    • Use a plastic opening tool to remove the speed knob.
    • Use a plastic opening tool to remove the long plastic piece
    • Use a plastic opening tool to remove the speed switch.
  3. KitchenAid KHM512ER Eject Button Spring Replacement: step 3, image 1 of 2 KitchenAid KHM512ER Eject Button Spring Replacement: step 3, image 2 of 2
    • Use a Phillips 2 screwdriver to remove the two 20.0mm screws holding the bottom plastic piece on.
    • Your screwdriver may not be long or narrow enough to reach the screws in these holes. If that's the case, use another screwdriver.
    • Remove the bottom plastic piece using a plastic opening tool.
  4. KitchenAid KHM512ER Eject Button Spring Replacement: step 4, image 1 of 3 KitchenAid KHM512ER Eject Button Spring Replacement: step 4, image 2 of 3 KitchenAid KHM512ER Eject Button Spring Replacement: step 4, image 3 of 3
    • Using a Phillips 2 screwdriver, remove the three 20.0mm screws holding the motor assembly in place.
    • Use your hands to remove the motor assembly.
    • Use your hands to hold the eject button from one side while using the other hand to remove the circuit board.
  5. KitchenAid KHM512ER Eject Button Spring Replacement: step 5, image 1 of 2 KitchenAid KHM512ER Eject Button Spring Replacement: step 5, image 2 of 2
    • Remove the eject button by pulling it from the inside of the mixer.
    • Hold the eject button firmly while pulling out the spring.
2 other people completed this guide.
Yuriy Zaynulin
191 Reputation
1 Guide authored
USF Tampa, Team 2-3, Sullivan Spring 2016 Member of USF Tampa, Team 2-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G3
3 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 1,876
