KitchenAid KHM512ER Motor Replacement
  1. KitchenAid KHM512ER Motor Replacement, Motor: step 1, image 1 of 2 KitchenAid KHM512ER Motor Replacement, Motor: step 1, image 2 of 2
    • Insert the back of a plastic opening tool into one of the beater holes
    • Apply force to pull the circular plastic part off.
    • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
  2. KitchenAid KHM512ER Motor Replacement: step 2, image 1 of 2 KitchenAid KHM512ER Motor Replacement: step 2, image 2 of 2
    • Use a Phillips 2 screwdriver to remove the two 20mm screws holding the bottom plastic piece in place.
    • Remove the bottom plastic piece using a plastic opening tool.
    • Your screwdriver may not be long or narrow enough to reach the screws in these holes. If that's the case, use another screwdriver.
  3. KitchenAid KHM512ER Motor Replacement: step 3, image 1 of 2 KitchenAid KHM512ER Motor Replacement: step 3, image 2 of 2
    • Using a Phillips 2 screwdriver, remove the three 20mm screws holding the motor assembly in place.
    • Use your hands to remove the motor assembly and circuit board.
  4. KitchenAid KHM512ER Motor Replacement: step 4, image 1 of 3 KitchenAid KHM512ER Motor Replacement: step 4, image 2 of 3 KitchenAid KHM512ER Motor Replacement: step 4, image 3 of 3
    • Firmly grip the motor in your hand. Using pliers, pull the connectors off the motors.
    • Some force may be required. Be careful not to cut yourself on any electrical components.
2 other people completed this guide.
[deleted]
134 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 43
All Time: 5,167
