KitchenAid KHM512ER Power Cord Replacement
  1. KitchenAid KHM512ER Power Cord Replacement, Power Cord: step 1, image 1 of 2 KitchenAid KHM512ER Power Cord Replacement, Power Cord: step 1, image 2 of 2
    • Insert the back of a plastic opening tool into one of the beater holes
    • Apply force to pull the circular plastic part off.
    • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
  2. KitchenAid KHM512ER Power Cord Replacement: step 2, image 1 of 3 KitchenAid KHM512ER Power Cord Replacement: step 2, image 2 of 3 KitchenAid KHM512ER Power Cord Replacement: step 2, image 3 of 3
    • Use a plastic opening tool to remove the speed knob.
    • Pop up the panel with a plastic opening tool.
    • Use a plastic opening tool to pry the white plastic switch assembly out.
  3. KitchenAid KHM512ER Power Cord Replacement: step 3, image 1 of 2 KitchenAid KHM512ER Power Cord Replacement: step 3, image 2 of 2
    • Use a Phillips 2 screwdriver to remove the two 20.0mm screws that hold the bottom plastic piece.
    • Your screwdriver may not be long or narrow enough to reach the screws in these holes. If that's the case, use another screwdriver.
    • Remove the bottom plastic piece using a plastic opening tool.
  4. KitchenAid KHM512ER Power Cord Replacement: step 4, image 1 of 3 KitchenAid KHM512ER Power Cord Replacement: step 4, image 2 of 3 KitchenAid KHM512ER Power Cord Replacement: step 4, image 3 of 3
    • Using a Phillips 2 screwdriver, remove the three 20.0mm screws holding the motor assembly in place.
    • Use your hands to remove the motor assembly and circuit board.
  5. KitchenAid KHM512ER Power Cord Replacement: step 5, image 1 of 3 KitchenAid KHM512ER Power Cord Replacement: step 5, image 2 of 3 KitchenAid KHM512ER Power Cord Replacement: step 5, image 3 of 3
    • Firmly grip the circuit board, and using pliers, remove the black and white power cord connectors from the circuit board.
    • Some force may be required. Be careful not to cut yourself on any electrical components.
  6. KitchenAid KHM512ER Power Cord Replacement: step 6, image 1 of 3 KitchenAid KHM512ER Power Cord Replacement: step 6, image 2 of 3 KitchenAid KHM512ER Power Cord Replacement: step 6, image 3 of 3
    • Using a plastic opening tool, remove the white plastic clip on the inside of the bottom plastic piece.
    • Once it's loose, remove it with your fingers.
    • Pull the power cord through the hole.
Brad Daniels
621 Reputation
3 Guides authored
USF Tampa, Team 2-3, Sullivan Spring 2016 Member of USF Tampa, Team 2-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G3
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 22
All Time: 3,643
