KitchenAid KSM150PSER Carbon Brushes Replacement
  1. KitchenAid KSM150PSER Carbon Brushes Replacement, Carbon Brushes: step 1, image 1 of 2 KitchenAid KSM150PSER Carbon Brushes Replacement, Carbon Brushes: step 1, image 2 of 2
    • Using a flat head screwdriver, unscrew the brush cap on each side of the mixer by turning them counter clockwise.
    • Remove brush cap by pulling it toward you.
    • The brushes are held in by springs and will fly out if removed too fast.
  2. KitchenAid KSM150PSER Carbon Brushes Replacement: step 2, image 1 of 1
    • Remove brush by pulling it toward you.
    • One corner of the brush is flattened. You can check which way the brush is oriented by shining a flashlight inside the hole.
8 other people completed this guide.
Hayley Young
253 Reputation
1 Guide authored
Cal Poly, Team S2-G5, Livingston Winter 2018 Member of Cal Poly, Team S2-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G5
4 Members
11 Guides authored
One Comment
I’ve been procrastinating on trying to fix my KA mixer on my own…today I did it. The directions were pretty clear and the only thing wrong was that when I had previously cleaned my mixer, I put the carbon brushes in the wrong way. Once I shined a flashlight into the hole I could see where the notched corner went.
Amber Reimer - Reply
Past 24 Hours: 15
Past 7 Days: 33
Past 30 Days: 199
All Time: 16,692
