KitchenAid KSM150PSER Circuit Board Replacement
  1. KitchenAid KSM150PSER Circuit Board Replacement, Circuit Board: step 1, image 1 of 2 KitchenAid KSM150PSER Circuit Board Replacement, Circuit Board: step 1, image 2 of 2
    • Using a Phillips #2 screwdriver, remove the 10mm screw on the back cover by rotating it counterclockwise.
    • The back cover is now free. Remove it by pulling it back and up.
    • Ensure that the mixer is disconnected from any electrical source prior to removing the back cover.
  2. KitchenAid KSM150PSER Circuit Board Replacement: step 2, image 1 of 2 KitchenAid KSM150PSER Circuit Board Replacement: step 2, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the 9.5mm screw above the circuit board by rotating it counterclockwise.
    • If you can't see the screw, try pulling the seal down past the wires to make the screw more accessible.
  3. KitchenAid KSM150PSER Circuit Board Replacement: step 3, image 1 of 2 KitchenAid KSM150PSER Circuit Board Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Using pliers or tweezers, remove the connectors of the four wires attached to the circuit board.
  4. KitchenAid KSM150PSER Circuit Board Replacement: step 4, image 1 of 1
    • Grab the wires and tilt the edge of the board up to lift the circuit board up and out.
4 other people completed this guide.
Luke Leonard
616 Reputation
2 Guides authored
Cal Poly, Team S2-G5, Livingston Winter 2018 Member of Cal Poly, Team S2-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G5
4 Members
11 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 89
All Time: 5,977
