KitchenAid KSM150PSER Power Cord Replacement
  1. KitchenAid KSM150PSER Power Cord Replacement, Power Cord: step 1, image 1 of 2 KitchenAid KSM150PSER Power Cord Replacement, Power Cord: step 1, image 2 of 2
    • Using a Phillips #2 screwdriver, remove the 10mm screw on the back cover by rotating it counterclockwise.
    • The back cover is now free. Remove it by pulling back and up on the cover.
  2. KitchenAid KSM150PSER Power Cord Replacement: step 2, image 1 of 2 KitchenAid KSM150PSER Power Cord Replacement: step 2, image 2 of 2
    • Using a Phillips #2 screwdriver, remove the 5mm screws holding the trimband to the top housing by rotating them counterclockwise.
    • Pull the trimband off the housing by grabbing each side and pulling it off the front.
  3. KitchenAid KSM150PSER Power Cord Replacement: step 3, image 1 of 2 KitchenAid KSM150PSER Power Cord Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Using a Phillips #2 screwdriver, remove the 12mm screw holding the grounding wire in place by rotating it counterclockwise.
    • Using pliers or tweezers, remove the connectors attached to the white and black wires.
  4. KitchenAid KSM150PSER Power Cord Replacement: step 4, image 1 of 2 KitchenAid KSM150PSER Power Cord Replacement: step 4, image 2 of 2
    • Using a screwdriver, pull the cord string relief out of the mixer by putting it behind the cord and pulling away from the mixer until it is free.
    • Remove the cord from the mixer body.
Max Prohorov
109 Reputation
1 Guide authored
Cal Poly, Team S2-G5, Livingston Winter 2018 Member of Cal Poly, Team S2-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G5
4 Members
11 Guides authored
0 Comments
Past 24 Hours: 6
Past 7 Days: 23
Past 30 Days: 117
All Time: 4,772
