Kobo Arc K107 Battery Replacement
  1. Kobo Arc K107 Battery Replacement, Battery: step 1, image 1 of 1
    • Peel the back cover off of the Kobo Arc by finding the lip in the cover and pulling back on it.
  2. Kobo Arc K107 Battery Replacement: step 2, image 1 of 1
    • Remove the screws from the midframe.
  3. Kobo Arc K107 Battery Replacement: step 3, image 1 of 1
    • Use a nylon spudger to pry up the battery from the device.
    • It will give some resistance as it is glued down.
    • Always use plastic or nylon prying tools around the battery. Metal tools can puncture a battery, potentially causing a fire.
  4. Kobo Arc K107 Battery Replacement: step 4, image 1 of 1
    • Unplug the battery connector from the rest of the tablet.
    • Remove the battery from the tablet.
Stephen Pehl
303 Reputation
2 Guides authored
One Comment
Top pour redémarrer un kobo arc 7 en décharge profonde : débrancher la batterie, connexion chargeur (ça s'allume!), déconnection chargeur, rebrancher la batterie et mettre en charge. Par contre la batterie est introuvable.. on verra une fois chargé si ça tiens encore. merci
vincepolshki - Reply
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 41
All Time: 1,350
