Kobo Arc K107 Speaker Replacement
  1. Kobo Arc K107 Speaker Replacement, Battery: step 1, image 1 of 1
    • Peel the back cover off of the Kobo Arc by finding the lip in the cover and pulling back on it.
  2. Kobo Arc K107 Speaker Replacement: step 2, image 1 of 1
    • Remove the screws from the midframe.
  3. Kobo Arc K107 Speaker Replacement: step 3, image 1 of 1
    • Use a nylon spudger to pry up the battery from the device.
    • It will give some resistance as it is glued down.
    • Always use plastic or nylon prying tools around the battery. Metal tools can puncture a battery, potentially causing a fire.
  4. Kobo Arc K107 Speaker Replacement: step 4, image 1 of 1
    • Unplug the battery connector from the rest of the tablet.
    • Remove the battery from the tablet.
  5. Kobo Arc K107 Speaker Replacement, Speaker: step 5, image 1 of 2 Kobo Arc K107 Speaker Replacement, Speaker: step 5, image 2 of 2
    • Remove the screws that are attached to the grey plastic layer.
    • Remove the gray plastic layer.
  6. Kobo Arc K107 Speaker Replacement: step 6, image 1 of 1
    • Disconnect the speakers from the tablet.
Luke Maalouf
85 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 100
