Kobo Aura HD Screen Replacement
  1. Kobo Aura HD Screen Replacement, Remove front bezel: step 1, image 1 of 3 Kobo Aura HD Screen Replacement, Remove front bezel: step 1, image 2 of 3 Kobo Aura HD Screen Replacement, Remove front bezel: step 1, image 3 of 3
    • Starting at the bottom right corner, use a plastic spudger to separate the front bezel from the case.
    • Work along the bottom, then up the side, slowly going all the way around the device.
  2. Kobo Aura HD Screen Replacement, Remove rear casing: step 2, image 1 of 2 Kobo Aura HD Screen Replacement, Remove rear casing: step 2, image 2 of 2
    • Using a Phillips #000 screwdriver, remove the 4 screws at the corners of the display.
    • Remove the display and motherboard assembly from the back plate.
  3. Kobo Aura HD Screen Replacement, Disconnect the battery: step 3, image 1 of 2 Kobo Aura HD Screen Replacement, Disconnect the battery: step 3, image 2 of 2
    • Pry the battery connector up, away from (i.e. perpendicular to) the board to disconnect it.
    • You may find it useful to use the spudging tool for this.
  4. Kobo Aura HD Screen Replacement, Disconnect main display cable: step 4, image 1 of 3 Kobo Aura HD Screen Replacement, Disconnect main display cable: step 4, image 2 of 3 Kobo Aura HD Screen Replacement, Disconnect main display cable: step 4, image 3 of 3
    • Gently open the Zero Insertion Force (ZIF) connector holding in the display cable.
    • You may find it easier to pry it open with your spudger.
    • The connector is hinged, and opens upwards. The hinge is on the right-hand side, so you should pry on the left-hand side.
    • Once the connector is open, gently pull the cable to the left to slide it out.
  5. Kobo Aura HD Screen Replacement, Disconnect the second display cable: step 5, image 1 of 3 Kobo Aura HD Screen Replacement, Disconnect the second display cable: step 5, image 2 of 3 Kobo Aura HD Screen Replacement, Disconnect the second display cable: step 5, image 3 of 3
    • Gently open the second, smaller Zero Insertion Force connector by prying up the brown pressure-clip from the bottom.
    • Slide the cable down to disconnect it.
    • On the back of the display cable, you will find the full model number of your display, which you should use when searching for a replacement to ensure you get the correct part.
  6. Kobo Aura HD Screen Replacement, Remove the motherboard: step 6, image 1 of 3 Kobo Aura HD Screen Replacement, Remove the motherboard: step 6, image 2 of 3 Kobo Aura HD Screen Replacement, Remove the motherboard: step 6, image 3 of 3
    • Using a Phillips #000 screwdriver, remove the 6 screws holding the display to the motherboard.
    • Separate the board from the display assembly.
  7. Kobo Aura HD Screen Replacement, Separate the display from the frame: step 7, image 1 of 3 Kobo Aura HD Screen Replacement, Separate the display from the frame: step 7, image 2 of 3 Kobo Aura HD Screen Replacement, Separate the display from the frame: step 7, image 3 of 3
    • The glass backing of the display is secured to the metal frame with adhesive strips. Slowly and gently pry the two apart.
    • Note: it is very difficult to do this without breaking the glass. Go slowly and don't apply a lot of force.
    • If you break the glass, make sure you have cleared away all pieces of it before attempting to install the new display.
  8. Kobo Aura HD Screen Replacement, Install the new display: step 8, image 1 of 2 Kobo Aura HD Screen Replacement, Install the new display: step 8, image 2 of 2
    • Fit the screen into the notches at the base of the frame to ensure it is correctly aligned.
    • Feed the display and power cables through the cutouts in the frame.
    • If you replace the display immediately after removing the old one, you should be able to re-use the existing adhesive.
  9. Kobo Aura HD Screen Replacement, Press the display into place: step 9, image 1 of 1
    • Carefully align the screen with the frame and press it in to place.
    • Apply gentle, even pressure for 5-10 minutes to adhere the screen in place.
    • Be careful not to pinch the display cable between the display and frame.
  10. Kobo Aura HD Screen Replacement, Reassembly: step 10, image 1 of 1
    • Perform the above steps in reverse to reassemble the device
    • Once you have reconnected the display and power cables, and screwed the motherboard back in place, you can turn the device on to confirm the display is connected properly and working.
    • Note that it will not respond to touch until the front bezel is reinstalled.
    • Be careful of bending the display when reassembling it. It is very fragile and easily broken.
41 other people completed this guide.
Spencer Harding
1,411 Reputation
1 Guide authored
58 Comments
Hi,
Many thanks for your tutorial.
One quick question, where did you buy the replacement screen?
Many thanks in advance for your help.
Kind regards
King Koton - Reply
Hello, King Koton,
I already had another broken Kobo, so I could reuse the screen. I don’t think you can buy original parts, so maybe you will have to get a broken Kobo at an auction.
Good luck, John
John Maier -
Hi King Koton, I brought a brand new screen on AliExpress, look for ED0680G1 (the Kobo Aura HD uses the exact same screen as the Kobo Aura H2O).
Marc -
Hello John, Ur information did helped me for 100%. We reinstalled a screen to based on ur guide. But i have a question. After reinstalling the front bezel the touch screen is responding reliable. sometimes he doesnt turn a page or somtimes turn more then one page etc. I usend also there the existing adhesive. Can that  be a the reason of less responding quality. I hope u have an advice. Kind regards, Jan de Jong
Jan de Jong - Reply
Sorry Jan, I don’t know either. Maybe someone else can give advice. Good luck. (This guide was written by Spencer Harding, I only added one comment), John
John Maier -
Past 24 Hours: 39
Past 7 Days: 201
Past 30 Days: 846
All Time: 68,815
