Kobo Glo E-reader USB Port Replacement
  1. Kobo Glo E-reader USB Port Replacement, Remove the back panel and the screws.: step 1, image 1 of 2 Kobo Glo E-reader USB Port Replacement, Remove the back panel and the screws.: step 1, image 2 of 2
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • Make sure to store the screws somewhere you won't loose them, like on your FixMat.
  2. Kobo Glo E-reader USB Port Replacement, Disconnect the ribbon cable: step 2, image 1 of 1
    • All you have to do is lift the black locking arm that is keeping the ribbon cable in place. See picture.
  3. Kobo Glo E-reader USB Port Replacement, Remove the motherboard: step 3, image 1 of 1
    • Carefully remove the motherboard from your e-reader.
  4. Kobo Glo E-reader USB Port Replacement, Check the voltage on all six motherboard pins: step 4, image 1 of 1
    • Check the voltage of all six pins: if a pin shows no voltage level this probably means the pin is loose.
  5. Kobo Glo E-reader USB Port Replacement, Resolder the disconnected pin(s): step 5, image 1 of 1
    • Use as much flux as possible (i.e. with the use of a flux marker).
    • A magnifying camera makes the job a lot easier.
    • Make sure that the pins are not touching each other.
  6. Kobo Glo E-reader USB Port Replacement, Put back the motherboard: step 6, image 1 of 2 Kobo Glo E-reader USB Port Replacement, Put back the motherboard: step 6, image 2 of 2
    • Carefully reassemble the parts.
  7. Kobo Glo E-reader USB Port Replacement, Final check: step 7, image 1 of 1
    • Make sure that the e-reader functions properly before completely reassembling and closing it.
Finish Line
2 other people completed this guide.
Special thanks to these translators:
nl en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Laura Ahsmann
274 Reputation
1 Guide authored
6 Comments
My on/off button stopped working. The kobo won't start.... Thank you!
E K - Reply
I needed to see how the USB plug was aligned on the motherboard and your guide showed me exactly this. Since I am not able to solder I will ask someone else to do the job, but at least I know I tried my best. Thank you.
VooBee - Reply
Where did you buy the replacement part from?
Techie -
Hello guys, two of the pins on my reader are broken and I can't find the exact micro usb b model to buy the replacement.
Do you recommend a website to get it from?
Thanks a lot for your help
Edu Insua - Reply
There was one on Ebay
Test taaaa -
Past 24 Hours: 12
Past 7 Days: 62
Past 30 Days: 196
All Time: 7,326
