Kobo Glo HD Rear Cover Replacement
  1. Kobo Glo HD Rear Cover Replacement, Rear Cover: step 1, image 1 of 3 Kobo Glo HD Rear Cover Replacement, Rear Cover: step 1, image 2 of 3 Kobo Glo HD Rear Cover Replacement, Rear Cover: step 1, image 3 of 3
    • If you haven't done so already, power off your eReader by holding down the power button for 3 seconds until the display refreshes to indicate that it has powered off.
    • Opening picks are required for this step as opening tools can be too wide to get into the gap between the rear cover and the side/front.
    • Start by inserting the pick into the area around the power button or Micro USB port.
    • Don't insert it too far, as that could result in damage to the power button, status indicator, and/or Micro USB port.
    • Then, slide the pick around to undo these clips.
  2. Kobo Glo HD Rear Cover Replacement: step 2, image 1 of 3 Kobo Glo HD Rear Cover Replacement: step 2, image 2 of 3 Kobo Glo HD Rear Cover Replacement: step 2, image 3 of 3
    • The rear cover should then pop off.
Kevin Bhasi
1,262 Reputation
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 12
All Time: 740
