Kodak EasyShare C195 Batteries Replacement
  1. Kodak EasyShare C195 Batteries Replacement, Batteries: step 1, image 1 of 3 Kodak EasyShare C195 Batteries Replacement, Batteries: step 1, image 2 of 3 Kodak EasyShare C195 Batteries Replacement, Batteries: step 1, image 3 of 3
    • First, open the cover to the batteries. This is located on the bottom left of the camera.
    • Push the door down and to the left to open. This opens into the batteries and the memory card.
  2. Kodak EasyShare C195 Batteries Replacement: step 2, image 1 of 3 Kodak EasyShare C195 Batteries Replacement: step 2, image 2 of 3 Kodak EasyShare C195 Batteries Replacement: step 2, image 3 of 3
    • To insert the batteries, place them in the slots provided.
    • Make sure the positive and negative signs match with the positive and negative sides of the batteries.
  3. Kodak EasyShare C195 Batteries Replacement: step 3, image 1 of 3 Kodak EasyShare C195 Batteries Replacement: step 3, image 2 of 3 Kodak EasyShare C195 Batteries Replacement: step 3, image 3 of 3
    • When finished, you should have one battery positive side up and the other one negative side up.
To close the door, push the door down and slide to the right
Alyssa
96 Reputation
4 Guides authored
Cal Poly, Team 6-22, Amido Spring 2012 Member of Cal Poly, Team 6-22, Amido Spring 2012
CPSU-AMIDO-S12S6G22
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 63
All Time: 3,203
