Kodak EasyShare C713 Battery Door Replacement
  1. Kodak EasyShare C713 Battery Door Replacement, Batteries: step 1, image 1 of 1
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Kodak EasyShare C713 Battery Door Replacement: step 2, image 1 of 1
    • Remove the old batteries.
  3. Kodak EasyShare C713 Battery Door Replacement, Outer Case: step 3, image 1 of 3 Kodak EasyShare C713 Battery Door Replacement, Outer Case: step 3, image 2 of 3 Kodak EasyShare C713 Battery Door Replacement, Outer Case: step 3, image 3 of 3
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  4. Kodak EasyShare C713 Battery Door Replacement: step 4, image 1 of 3 Kodak EasyShare C713 Battery Door Replacement: step 4, image 2 of 3 Kodak EasyShare C713 Battery Door Replacement: step 4, image 3 of 3
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  5. Kodak EasyShare C713 Battery Door Replacement, Battery Door: step 5, image 1 of 2 Kodak EasyShare C713 Battery Door Replacement, Battery Door: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Make sure the battery door is open.
    • Using a pair of tweezers, remove the metal rod at the junction of the battery door and the inner camera case.
    • This rod serves as the hinge for the door.
    • Make sure not to lose the battery door spring which may fall when the rod is removed.
Trevor DeVore
17 Reputation
1 Guide authored
Cal Poly, Team 26-19, Regan Spring 2010 Member of Cal Poly, Team 26-19, Regan Spring 2010
CPSU-REGAN-S10S26G19
4 Members
14 Guides authored
One Comment
Where do I buy a new battery door. Cheers, Peter
Peter - Reply
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 33
All Time: 5,241
