Kodak EasyShare C713 LCD Replacement
  1. Kodak EasyShare C713 LCD Replacement, Batteries: step 1, image 1 of 1
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Kodak EasyShare C713 LCD Replacement: step 2, image 1 of 1
    • Remove the old batteries.
  3. Kodak EasyShare C713 LCD Replacement, Outer Case: step 3, image 1 of 3 Kodak EasyShare C713 LCD Replacement, Outer Case: step 3, image 2 of 3 Kodak EasyShare C713 LCD Replacement, Outer Case: step 3, image 3 of 3
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  4. Kodak EasyShare C713 LCD Replacement: step 4, image 1 of 3 Kodak EasyShare C713 LCD Replacement: step 4, image 2 of 3 Kodak EasyShare C713 LCD Replacement: step 4, image 3 of 3
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  5. Kodak EasyShare C713 LCD Replacement, LCD: step 5, image 1 of 1
    • The LCD screen is hinged at the bottom.
    • Put your thumb in the upper right corner of the LCD screen.
    • Pull the LCD screen out of its outer case with your thumb.
  6. Kodak EasyShare C713 LCD Replacement: step 6, image 1 of 1
    • Remove the screw underneath LCD screen with the Phillips #00. The screw measures 4.1mm in length.
  7. Kodak EasyShare C713 LCD Replacement: step 7, image 1 of 2 Kodak EasyShare C713 LCD Replacement: step 7, image 2 of 2
    • Desolder the two points.
    • One on the port side.
    • One on the bottom.
  8. Kodak EasyShare C713 LCD Replacement: step 8, image 1 of 1
    • After desoldering the LCD casing, just use your fingers to carefully remove it.
  9. Kodak EasyShare C713 LCD Replacement: step 9, image 1 of 1
    • Flip up the black tab on the bottom of the LCD screen with a fingertip.
  10. Kodak EasyShare C713 LCD Replacement: step 10, image 1 of 1
    • Remove the LCD ribbon cable from inside the black tab.
6 other people completed this guide.
Taggart Ashby
354 Reputation
4 Guides authored
Cal Poly, Team 26-19, Regan Spring 2010 Member of Cal Poly, Team 26-19, Regan Spring 2010
CPSU-REGAN-S10S26G19
4 Members
14 Guides authored
2 Comments
Thank you... i fixed my old camera lcd.
anthoxman - Reply
hvor kan jeg kjøpe LCD skjermen til dette kamerat, og hva koster et sånn LCD-skjerm
fancy tassen - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 27
All Time: 5,343
