Kodak EasyShare C913 Front Case Replacement
  1. Kodak EasyShare C913 Front Case Replacement, Batteries: step 1, image 1 of 3 Kodak EasyShare C913 Front Case Replacement, Batteries: step 1, image 2 of 3 Kodak EasyShare C913 Front Case Replacement, Batteries: step 1, image 3 of 3
    • Position the camera with the bottom facing up.
    • Slide the battery cover in the direction of the arrow with your finger gently.
    • Remove the batteries
  2. Kodak EasyShare C913 Front Case Replacement, Back Case: step 2, image 1 of 3 Kodak EasyShare C913 Front Case Replacement, Back Case: step 2, image 2 of 3 Kodak EasyShare C913 Front Case Replacement, Back Case: step 2, image 3 of 3
    • Remove the seven 4.5mm screws with a Phillips #00 screwdriver.
    • 2 on the left
    • 2 on the right
    • 3 on the bottom
  3. Kodak EasyShare C913 Front Case Replacement: step 3, image 1 of 3 Kodak EasyShare C913 Front Case Replacement: step 3, image 2 of 3 Kodak EasyShare C913 Front Case Replacement: step 3, image 3 of 3
    • Firmly grasp the back of the camera and pull the away the casing.
  4. Kodak EasyShare C913 Front Case Replacement, Front Case: step 4, image 1 of 3 Kodak EasyShare C913 Front Case Replacement, Front Case: step 4, image 2 of 3 Kodak EasyShare C913 Front Case Replacement, Front Case: step 4, image 3 of 3
    • Keep the battery door open
    • Firmly grasp the front casing and pull away from the camera.
2 other people completed this guide.
Dustin Rodgers
65 Reputation
4 Guides authored
Cal Poly, Team 7-51, Amido Fall 2010 Member of Cal Poly, Team 7-51, Amido Fall 2010
CPSU-AMIDO-F10S7G51
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 2,989
