Kodak EasyShare C913 LCD Screen Replacement
  1. Kodak EasyShare C913 LCD Screen Replacement, Batteries: step 1, image 1 of 3 Kodak EasyShare C913 LCD Screen Replacement, Batteries: step 1, image 2 of 3 Kodak EasyShare C913 LCD Screen Replacement, Batteries: step 1, image 3 of 3
    • Position the camera with the bottom facing up.
    • Slide the battery cover in the direction of the arrow with your finger gently.
    • Remove the batteries
  2. Kodak EasyShare C913 LCD Screen Replacement, Back Case: step 2, image 1 of 3 Kodak EasyShare C913 LCD Screen Replacement, Back Case: step 2, image 2 of 3 Kodak EasyShare C913 LCD Screen Replacement, Back Case: step 2, image 3 of 3
    • Remove the seven 4.5mm screws with a Phillips #00 screwdriver.
    • 2 on the left
    • 2 on the right
    • 3 on the bottom
  3. Kodak EasyShare C913 LCD Screen Replacement: step 3, image 1 of 3 Kodak EasyShare C913 LCD Screen Replacement: step 3, image 2 of 3 Kodak EasyShare C913 LCD Screen Replacement: step 3, image 3 of 3
    • Firmly grasp the back of the camera and pull the away the casing.
  4. Kodak EasyShare C913 LCD Screen Replacement, Front Case: step 4, image 1 of 3 Kodak EasyShare C913 LCD Screen Replacement, Front Case: step 4, image 2 of 3 Kodak EasyShare C913 LCD Screen Replacement, Front Case: step 4, image 3 of 3
    • Keep the battery door open
    • Firmly grasp the front casing and pull away from the camera.
  5. Kodak EasyShare C913 LCD Screen Replacement, LCD Screen: step 5, image 1 of 3 Kodak EasyShare C913 LCD Screen Replacement, LCD Screen: step 5, image 2 of 3 Kodak EasyShare C913 LCD Screen Replacement, LCD Screen: step 5, image 3 of 3
    • Locate the 2 solder joints on both sides of the LCD casing.
    • De-solder the joints.
  6. Kodak EasyShare C913 LCD Screen Replacement: step 6, image 1 of 3 Kodak EasyShare C913 LCD Screen Replacement: step 6, image 2 of 3 Kodak EasyShare C913 LCD Screen Replacement: step 6, image 3 of 3
    • Gently grasp the lower right side of LCD screen.
    • Lift the screen out of its casing.
    • Remove 3mm screw from LCD casing using #00 screwdriver.
  7. Kodak EasyShare C913 LCD Screen Replacement: step 7, image 1 of 3 Kodak EasyShare C913 LCD Screen Replacement: step 7, image 2 of 3 Kodak EasyShare C913 LCD Screen Replacement: step 7, image 3 of 3
    • Gently grab the sides of the LCD casing and remove it from the camera
  8. Kodak EasyShare C913 LCD Screen Replacement: step 8, image 1 of 2 Kodak EasyShare C913 LCD Screen Replacement: step 8, image 2 of 2
    • Lift the black tab with your finger
    • Gently remove ribbon from underneath black tab.
Alan Galarza
72 Reputation
3 Guides authored
Cal Poly, Team 7-51, Amido Fall 2010 Member of Cal Poly, Team 7-51, Amido Fall 2010
CPSU-AMIDO-F10S7G51
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 26
All Time: 4,302
