Kodak EasyShare LS743 Camera Case Disassembly
  1. Kodak EasyShare LS743 Camera Case Disassembly, Kodak EasyShare LS743 Camera Case Disassembly: step 1, image 1 of 3 Kodak EasyShare LS743 Camera Case Disassembly, Kodak EasyShare LS743 Camera Case Disassembly: step 1, image 2 of 3 Kodak EasyShare LS743 Camera Case Disassembly, Kodak EasyShare LS743 Camera Case Disassembly: step 1, image 3 of 3
    • Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
    • Remove the metal piece holding down the lanyard, then remove the lanyard.
  2. Kodak EasyShare LS743 Camera Case Disassembly: step 2, image 1 of 3 Kodak EasyShare LS743 Camera Case Disassembly: step 2, image 2 of 3 Kodak EasyShare LS743 Camera Case Disassembly: step 2, image 3 of 3
    • Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
    • One 6.25 mm screw is located on the top right corner, right to the "OK" button.
    • Four 4.45 mm screws are on the bottom of the camera.
    • Two 2.95 mm screws are on the left side of the camera, above the USB port.
  3. Kodak EasyShare LS743 Camera Case Disassembly: step 3, image 1 of 2 Kodak EasyShare LS743 Camera Case Disassembly: step 3, image 2 of 2
    • Carefully remove the rear camera casing.
    • Carefully remove the front camera casing.
Michael
63 Reputation
2 Guides authored
Cal Poly, Team 2-8, Johann Summer 2010 Member of Cal Poly, Team 2-8, Johann Summer 2010
CPSU-JOHANN-R10S2G8
5 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 2,040
