Kodak EasyShare LS743 Microphone Replacement
  1. Kodak EasyShare LS743 Microphone Replacement, Battery: step 1, image 1 of 1
    • Using your fingernail, open the battery cover.
  2. Kodak EasyShare LS743 Microphone Replacement: step 2, image 1 of 1
    • Slide the orange latch sideways to eject the battery.
    • Remove the battery from the battery slot.
  3. Kodak EasyShare LS743 Microphone Replacement, Kodak EasyShare LS743 Camera Case Disassembly: step 3, image 1 of 3 Kodak EasyShare LS743 Microphone Replacement, Kodak EasyShare LS743 Camera Case Disassembly: step 3, image 2 of 3 Kodak EasyShare LS743 Microphone Replacement, Kodak EasyShare LS743 Camera Case Disassembly: step 3, image 3 of 3
    • Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
    • Remove the metal piece holding down the lanyard, then remove the lanyard.
  4. Kodak EasyShare LS743 Microphone Replacement: step 4, image 1 of 3 Kodak EasyShare LS743 Microphone Replacement: step 4, image 2 of 3 Kodak EasyShare LS743 Microphone Replacement: step 4, image 3 of 3
    • Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
    • One 6.25 mm screw is located on the top right corner, right to the "OK" button.
    • Four 4.45 mm screws are on the bottom of the camera.
    • Two 2.95 mm screws are on the left side of the camera, above the USB port.
  5. Kodak EasyShare LS743 Microphone Replacement: step 5, image 1 of 2 Kodak EasyShare LS743 Microphone Replacement: step 5, image 2 of 2
    • Carefully remove the rear camera casing.
    • Carefully remove the front camera casing.
  6. Kodak EasyShare LS743 Microphone Replacement, Top and menu buttons: step 6, image 1 of 2 Kodak EasyShare LS743 Microphone Replacement, Top and menu buttons: step 6, image 2 of 2
    • Remove the top panel screw (1x 4.37mm).
  7. Kodak EasyShare LS743 Microphone Replacement: step 7, image 1 of 2 Kodak EasyShare LS743 Microphone Replacement: step 7, image 2 of 2
    • Remove the top panel.
  8. Kodak EasyShare LS743 Microphone Replacement: step 8, image 1 of 2 Kodak EasyShare LS743 Microphone Replacement: step 8, image 2 of 2
    • Remove the back panel screws (1x 3.33mm, and 1x 3.40mm).
  9. Kodak EasyShare LS743 Microphone Replacement: step 9, image 1 of 3 Kodak EasyShare LS743 Microphone Replacement: step 9, image 2 of 3 Kodak EasyShare LS743 Microphone Replacement: step 9, image 3 of 3
    • Separate the inner casing from the tripod mount.
  10. Kodak EasyShare LS743 Microphone Replacement: step 10, image 1 of 3 Kodak EasyShare LS743 Microphone Replacement: step 10, image 2 of 3 Kodak EasyShare LS743 Microphone Replacement: step 10, image 3 of 3
    • Gently pull the orange tab out of the circuit board.
  11. Kodak EasyShare LS743 Microphone Replacement: step 11, image 1 of 2 Kodak EasyShare LS743 Microphone Replacement: step 11, image 2 of 2
    • Carefully separate and flip over the LCD panel to expose the central circuit board.
  12. Kodak EasyShare LS743 Microphone Replacement: step 12, image 1 of 1
    • Remove the (1x 3.33mm) screw from the menu button panel .
  13. Kodak EasyShare LS743 Microphone Replacement: step 13, image 1 of 2 Kodak EasyShare LS743 Microphone Replacement: step 13, image 2 of 2
    • Pull the second orange tab from the circuit board and remove the buttons.
  14. Kodak EasyShare LS743 Microphone Replacement, Removing LCD: step 14, image 1 of 3 Kodak EasyShare LS743 Microphone Replacement, Removing LCD: step 14, image 2 of 3 Kodak EasyShare LS743 Microphone Replacement, Removing LCD: step 14, image 3 of 3
    • Flip up the LCD screen to reveal the two orange ribbon cables.
    • Disconnect the two ribbons cables from their sockets on the motherboard.
  15. Kodak EasyShare LS743 Microphone Replacement, Microphone: step 15, image 1 of 1
    • Locate the microphone on top of the camera.
  16. Kodak EasyShare LS743 Microphone Replacement: step 16, image 1 of 1
    • With an opening tool, pry the microphone away from the camera carefully.
  17. Kodak EasyShare LS743 Microphone Replacement: step 17, image 1 of 1
    • Release the microphone from its pin and desolder.
Odessa
55 Reputation
2 Guides authored
Cal Poly, Team 2-8, Johann Summer 2010 Member of Cal Poly, Team 2-8, Johann Summer 2010
CPSU-JOHANN-R10S2G8
5 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 2,017
