Kodak EasyShare M381 Button Replacement
  1. Kodak EasyShare M381 Button Replacement, Battery: step 1, image 1 of 2 Kodak EasyShare M381 Button Replacement, Battery: step 1, image 2 of 2
    • First, press in and slide forward the battery latch as indicated by the arrow.
  2. Kodak EasyShare M381 Button Replacement: step 2, image 1 of 1
    • Press down on battery until you hear a click and release it. Battery should easily slide out.
  3. Kodak EasyShare M381 Button Replacement, Back Panel Frame: step 3, image 1 of 3 Kodak EasyShare M381 Button Replacement, Back Panel Frame: step 3, image 2 of 3 Kodak EasyShare M381 Button Replacement, Back Panel Frame: step 3, image 3 of 3
    • Remove the 3.9 mm frame screws using a Phillips #00 screwdriver.
    • Using a magnetized surface to keep from losing screws may be very helpful.
  4. Kodak EasyShare M381 Button Replacement: step 4, image 1 of 2 Kodak EasyShare M381 Button Replacement: step 4, image 2 of 2
    • Using both hands, carefully pull the frame apart from the camera.
  5. Kodak EasyShare M381 Button Replacement, Button: step 5, image 1 of 1
    • Carefully pick up frame and push upward on buttons.
  6. Kodak EasyShare M381 Button Replacement: step 6, image 1 of 1
    • Clean and replace as needed.
    • A microfiber cloth, or any other type of electronic cloth may be used to clean them if desire.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 14
All Time: 422
