Kodak EasyShare M381 Screen Replacement
  1. Kodak EasyShare M381 Screen Replacement, Battery: step 1, image 1 of 2 Kodak EasyShare M381 Screen Replacement, Battery: step 1, image 2 of 2
    • First, press in and slide forward the battery latch as indicated by the arrow.
  2. Kodak EasyShare M381 Screen Replacement: step 2, image 1 of 1
    • Press down on battery until you hear a click and release it. Battery should easily slide out.
  3. Kodak EasyShare M381 Screen Replacement, Back Panel Frame: step 3, image 1 of 3 Kodak EasyShare M381 Screen Replacement, Back Panel Frame: step 3, image 2 of 3 Kodak EasyShare M381 Screen Replacement, Back Panel Frame: step 3, image 3 of 3
    • Remove the 3.9 mm frame screws using a Phillips #00 screwdriver.
    • Using a magnetized surface to keep from losing screws may be very helpful.
  4. Kodak EasyShare M381 Screen Replacement: step 4, image 1 of 2 Kodak EasyShare M381 Screen Replacement: step 4, image 2 of 2
    • Using both hands, carefully pull the frame apart from the camera.
  5. Kodak EasyShare M381 Screen Replacement, Screen: step 5, image 1 of 1
    • Remove the two 3.85 mm screws on the bottom right of the camera, as indicated.
  6. Kodak EasyShare M381 Screen Replacement: step 6, image 1 of 1
    • Remove dial button located on top of camera, by gently pulling up.
  7. Kodak EasyShare M381 Screen Replacement: step 7, image 1 of 2 Kodak EasyShare M381 Screen Replacement: step 7, image 2 of 2
    • Starting at one side, carefully work the chrome frame off of the camera itself.
    • Be careful not to disturb the shutter or flash buttons on top of the camera.
  8. Kodak EasyShare M381 Screen Replacement: step 8, image 1 of 1
    • On the right side of the camera, locate and remove the two 3.25 mm screws as highlighted.
  9. Kodak EasyShare M381 Screen Replacement: step 9, image 1 of 3 Kodak EasyShare M381 Screen Replacement: step 9, image 2 of 3 Kodak EasyShare M381 Screen Replacement: step 9, image 3 of 3
    • Carefully lift the motherboard panel up, pulling towards the left. Make sure you do not rip the blue ribbon.
    • Using a plastic opening tool, gently lift up on the ribbon fastener until it is in an upright position.
    • Slide panel away from camera.
  10. Kodak EasyShare M381 Screen Replacement: step 10, image 1 of 2 Kodak EasyShare M381 Screen Replacement: step 10, image 2 of 2
    • Using a plastic opening tool, gently lift ribbon clamp as indicated to remove the screen ribbon from the motherboard.
    • Screen should now be detached. Gently lift it away from the base of the camera.
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 24
All Time: 491
