Kodak EasyShare M532 Screen Replacement
  1. Kodak EasyShare M532 Screen  Replacement, Screen: step 1, image 1 of 2 Kodak EasyShare M532 Screen  Replacement, Screen: step 1, image 2 of 2
    • Open the battery compartment on the bottom of the camera and remove the battery.
  2. Kodak EasyShare M532 Screen  Replacement: step 2, image 1 of 3 Kodak EasyShare M532 Screen  Replacement: step 2, image 2 of 3 Kodak EasyShare M532 Screen  Replacement: step 2, image 3 of 3
    • Remove two Phillips screws from each side of the camera (four screws total).
    • Remove one additional Phillips screw from the bottom of the camera.
  3. Kodak EasyShare M532 Screen  Replacement: step 3, image 1 of 3 Kodak EasyShare M532 Screen  Replacement: step 3, image 2 of 3 Kodak EasyShare M532 Screen  Replacement: step 3, image 3 of 3
    • Inserting the prying tool as shown, gently separate the front and back pieces of the camera exterior.
  4. Kodak EasyShare M532 Screen  Replacement: step 4, image 1 of 3 Kodak EasyShare M532 Screen  Replacement: step 4, image 2 of 3 Kodak EasyShare M532 Screen  Replacement: step 4, image 3 of 3
    • Carefully remove the front and back exterior pieces from the camera body.
  5. Kodak EasyShare M532 Screen  Replacement: step 5, image 1 of 3 Kodak EasyShare M532 Screen  Replacement: step 5, image 2 of 3 Kodak EasyShare M532 Screen  Replacement: step 5, image 3 of 3
    • Gently remove the frame with the top buttons.
    • You should now have the screen and inside parts exposed as shown.
  6. Kodak EasyShare M532 Screen  Replacement: step 6, image 1 of 2 Kodak EasyShare M532 Screen  Replacement: step 6, image 2 of 2
    • Lift the screen off the body. Note that it is still connected on one side by the orange tape.
    • Flip it over gently and let it rest off to the side where the tape is.
    • It is okay if the orange tape clips out of its spot.
  7. Kodak EasyShare M532 Screen  Replacement: step 7, image 1 of 2 Kodak EasyShare M532 Screen  Replacement: step 7, image 2 of 2
    • Remove the two Phillips screws. There is one at the top center and one in the bottom left corner.
  8. Kodak EasyShare M532 Screen  Replacement: step 8, image 1 of 3 Kodak EasyShare M532 Screen  Replacement: step 8, image 2 of 3 Kodak EasyShare M532 Screen  Replacement: step 8, image 3 of 3
    • Remove the top Phillips screw from the right side.
    • Move the silver tape aside to access and remove the Phillips screw in the bottom corner.
  9. Kodak EasyShare M532 Screen  Replacement: step 9, image 1 of 3 Kodak EasyShare M532 Screen  Replacement: step 9, image 2 of 3 Kodak EasyShare M532 Screen  Replacement: step 9, image 3 of 3
    • Gently pry up the clip on the top corner to release the metal casing and lift the casing out of the way.
    • The casing is also connected via an orange tape on the right side that you may leave in place.
    • Be sure to wear safety glasses while prying the clip.
  10. Kodak EasyShare M532 Screen  Replacement: step 10, image 1 of 3 Kodak EasyShare M532 Screen  Replacement: step 10, image 2 of 3 Kodak EasyShare M532 Screen  Replacement: step 10, image 3 of 3
    • Find the silver clip where the orange tape from the screen attaches to the circuit board.
    • Lift up the silver clip. The orange tape will slide out, completely disconnecting the screen from the camera.
1 Guide Comment
warning there are different revisions of this kind of camera. The M532 I got had the camera attached to the metal middle plate and not attached to the piece with the motherboard. This causes the camera's ribbon cable to become detached whenever opening the metal plate when trying to unplug the ribbon cable for the lcd screen. I have been unsuccessful in reattaching the 2 ribbon cables that go to the camera as the fit is too tight and the cables being too short. BE CAREFUL WHENEVER OPENING FOR THE FIRST TIME AND LOOK TO SEE IF THE CAMERA SENSOR IS ATTACHED TO THE METAL MIDDLE PLATE. screen is working beautifully just now the sensor has no power. Awesome step-by-step disassembly guide. I just got unlucky.
Dillon Coronado - Reply
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 35
All Time: 1,248
