Kodak Easyshare C813 Memory Card Replacement
  1. Kodak Easyshare C813 Memory Card Replacement, Memory Card: step 1, image 1 of 1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the mode selector dial.
  2. Kodak Easyshare C813 Memory Card Replacement: step 2, image 1 of 3 Kodak Easyshare C813 Memory Card Replacement: step 2, image 2 of 3 Kodak Easyshare C813 Memory Card Replacement: step 2, image 3 of 3
    • Locate battery compartment on bottom of camera and slide open by applying pressure in the direction of the arrow.
  3. Kodak Easyshare C813 Memory Card Replacement: step 3, image 1 of 2 Kodak Easyshare C813 Memory Card Replacement: step 3, image 2 of 2
    • Locate memory card slot and insert memory card by inserting the gold terminals first.
    • Apply pressure into you feel it lock into place.
    • Note: To remove a memory card, apply pressure down until you feel it click. Then it should pop up and you can just pull it up.
  4. Kodak Easyshare C813 Memory Card Replacement: step 4, image 1 of 2 Kodak Easyshare C813 Memory Card Replacement: step 4, image 2 of 2
    • Return the battery door to its formerly closed position.
  5. Kodak Easyshare C813 Memory Card Replacement: step 5, image 1 of 1
Samantha Murray
269 Reputation
3 Guides authored
Cal Poly, Team 24-22, Regan Spring 2010 Member of Cal Poly, Team 24-22, Regan Spring 2010
CPSU-REGAN-S10S24G22
4 Members
20 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 101
All Time: 9,619
