Kodak Easyshare V1003 LCD Display Replacement
  1. Kodak Easyshare V1003  LCD Display Replacement, Battery: step 1, image 1 of 1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera.
  2. Kodak Easyshare V1003  LCD Display Replacement: step 2, image 1 of 1
    • Position camera with the bottom facing up.
  3. Kodak Easyshare V1003  LCD Display Replacement: step 3, image 1 of 1
    • With your finger, slide the battery cover in the direction of the open arrow.
  4. Kodak Easyshare V1003  LCD Display Replacement: step 4, image 1 of 1
    • Lift the battery cover up gently.
  5. Kodak Easyshare V1003  LCD Display Replacement: step 5, image 1 of 2 Kodak Easyshare V1003  LCD Display Replacement: step 5, image 2 of 2
    • Gently push the battery down until a click is heard. Battery should release and be lifted out of slot.
  6. Kodak Easyshare V1003  LCD Display Replacement, Buttons: step 6, image 1 of 3 Kodak Easyshare V1003  LCD Display Replacement, Buttons: step 6, image 2 of 3 Kodak Easyshare V1003  LCD Display Replacement, Buttons: step 6, image 3 of 3
    • Use a J00 screwdriver to remove the five exterior screws.
  7. Kodak Easyshare V1003  LCD Display Replacement: step 7, image 1 of 3 Kodak Easyshare V1003  LCD Display Replacement: step 7, image 2 of 3 Kodak Easyshare V1003  LCD Display Replacement: step 7, image 3 of 3
    • Use a plastic opening tool to pry off the back casing.
  8. Kodak Easyshare V1003  LCD Display Replacement: step 8, image 1 of 3 Kodak Easyshare V1003  LCD Display Replacement: step 8, image 2 of 3 Kodak Easyshare V1003  LCD Display Replacement: step 8, image 3 of 3
    • Completely remove the back casing from the device.
    • Using a plastic tool to remove the bottom.
  9. Kodak Easyshare V1003  LCD Display Replacement, LCD Display: step 9, image 1 of 1
    • Remove the LCD display by unplugging the connector.
  10. Kodak Easyshare V1003  LCD Display Replacement: step 10, image 1 of 1
    • Take apart the LCD display from the back case.
2 other people completed this guide.
Vanessa Soares
246 Reputation
2 Guides authored
One Comment
Hi Vanessa
Where in South Africa (Gauteng) can I buy a lcd display replacement screen for this Kodak easyshare v1003 camera?
Wickus: +27725966377/ vwickus@ymail.com
vwickus - Reply
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 31
All Time: 930
