Kodak S100 EF Front Cover Replacement
  1. Kodak S100 EF Front Cover Replacement, Front Cover: step 1, image 1 of 1
    • Have the camera facing upwards and the flash closest to you.
    • Unscrew the two 6.2 mm Phillips screws on the top half of the camera.
  2. Kodak S100 EF Front Cover Replacement: step 2, image 1 of 1
    • Flip the camera over to the other side-with flash farthest from you.
    • Unscrew top two 6.2mm Phillips screws on this side.
  3. Kodak S100 EF Front Cover Replacement: step 3, image 1 of 1
    • Turn the camera so the bottom is facing up with the front-facing away.
    • Unscrew the 6.2mm Phillips screw on the top right.
    • The front cover is now unscrewed and should be lifted evenly and removed.
Michelle
107 Reputation
5 Guides authored
Cal Poly, Team 25-28, Garner Spring 2011 Member of Cal Poly, Team 25-28, Garner Spring 2011
CPSU-GARNER-S11S25G28
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 2,021
