Koosh Vortex Tornado Loading Spring Replacement
  1. Koosh Vortex Tornado Loading Spring Replacement, Barrel Shield Spring: step 1, image 1 of 1
    • Remove the fourteen 15 mm Phillips #1 screws on the side of the body.
  2. Koosh Vortex Tornado Loading Spring Replacement: step 2, image 1 of 1
    • Pull the halves of the toy gun apart to show the inside. Set the left half aside (all of the inside components are on the right half).
  3. Koosh Vortex Tornado Loading Spring Replacement: step 3, image 1 of 1
    • Using a spudger, unhook the barrel shield's spring from the right half of the toy gun. One side should still be connected to the shield barrel shield.
  4. Koosh Vortex Tornado Loading Spring Replacement, Trigger: step 4, image 1 of 1
    • Slide the barrel shield and shield slide off of the gun and set aside.
  5. Koosh Vortex Tornado Loading Spring Replacement: step 5, image 1 of 1
    • Slide the rubber ring off of the barrel and set it aside.
  6. Koosh Vortex Tornado Loading Spring Replacement: step 6, image 1 of 1
    • Lift the yellow trigger from its pin and set aside.
  7. Koosh Vortex Tornado Loading Spring Replacement, Loading Spring: step 7, image 1 of 1
    • Use a Phillips #1 screwdriver to unscrew the two 12 mm long washer head screws from the yellow loading bar lever.
  8. Koosh Vortex Tornado Loading Spring Replacement: step 8, image 1 of 1
    • Lift the yellow lever bar out of place and set aside.
  9. Koosh Vortex Tornado Loading Spring Replacement: step 9, image 1 of 1
    • Use a Phillips #1 Screwdriver to unscrew the six 10 mm long screws from the central firing assembly.
    • Use Phillips #1 Screwdriver to unscrew the four 9 mm long screws from the central firing assembly.
  10. Koosh Vortex Tornado Loading Spring Replacement: step 10, image 1 of 1
    • Pull the shell of the central firing assembly aside off (contains the loading spring).
  11. Koosh Vortex Tornado Loading Spring Replacement: step 11, image 1 of 2 Koosh Vortex Tornado Loading Spring Replacement: step 11, image 2 of 2
    • Open the back side of the central firing assembly apart to expose the loading spring. Remove it, and change it with your desired spring.
    • The two sides cannot be fully separated due to a pin holding the yellow collar tightly together.
Lingbin Meng
204 Reputation
2 Guides authored
IUPUI, Team 2-4, Harley Spring 2016 Member of IUPUI, Team 2-4, Harley Spring 2016
IUPUI-HARLEY-S16S2G4
4 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 31
All Time: 680
