Koosh Vortex Tornado Trigger Replacement
  1. Koosh Vortex Tornado Trigger Replacement, Barrel Shield Spring: step 1, image 1 of 1
    • Remove the fourteen 15 mm Phillips #1 screws on the side of the body.
  2. Koosh Vortex Tornado Trigger Replacement: step 2, image 1 of 1
    • Pull the halves of the toy gun apart to show the inside. Set the left half aside (all of the inside components are on the right half).
  3. Koosh Vortex Tornado Trigger Replacement: step 3, image 1 of 1
    • Using a spudger, unhook the barrel shield's spring from the right half of the toy gun. One side should still be connected to the shield barrel shield.
  4. Koosh Vortex Tornado Trigger Replacement, Trigger: step 4, image 1 of 1
    • Slide the barrel shield and shield slide off of the gun and set aside.
  5. Koosh Vortex Tornado Trigger Replacement: step 5, image 1 of 1
    • Slide the rubber ring off of the barrel and set it aside.
  6. Koosh Vortex Tornado Trigger Replacement: step 6, image 1 of 1
    • Lift the yellow trigger from its pin and set aside.
Lingbin Meng
204 Reputation
2 Guides authored
IUPUI, Team 2-4, Harley Spring 2016 Member of IUPUI, Team 2-4, Harley Spring 2016
IUPUI-HARLEY-S16S2G4
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 214
