Krups 963 Power Cord Replacement
  1. Krups 963 Power Cord Replacement, Removing Bottom Screws: step 1, image 1 of 1
    • Make sure the device is unplugged before continuing.
    • Use a Phillips size 2 screwdriver to remove the four 12mm screws found on the bottom of the machine.
  2. Krups 963 Power Cord Replacement: step 2, image 1 of 1
    • Remove the single black Phillips size 0 10mm length screw on the back of the machine.
  3. Krups 963 Power Cord Replacement: step 3, image 1 of 1
    • Remove the bottom cover from the machine and slide it down the power cord.
  4. Krups 963 Power Cord Replacement, Power Cord: step 4, image 1 of 2 Krups 963 Power Cord Replacement, Power Cord: step 4, image 2 of 2
    • Use the PH2 (or similar) screw driver to remove the two 12mm screws holding the clear restraining brace.
    • Remove the restraining brace from the machine base.
  5. Krups 963 Power Cord Replacement: step 5, image 1 of 1
    • Use a 2.0 flat head (or similar) screw driver to loosen the screw holding the power cord in.
Wyatt Hall
842 Reputation
7 Guides authored
Cal Poly, Team 6-25, Maness Fall 2014 Member of Cal Poly, Team 6-25, Maness Fall 2014
CPSU-MANESS-F14S6G25
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 877
