Krups F203 Coffee Grinder Base Plate Replacement
  1. Krups F203 Coffee Grinder Base Plate Replacement, Base Plate: step 1, image 1 of 1
    • In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
  2. Krups F203 Coffee Grinder Base Plate Replacement: step 2, image 1 of 3 Krups F203 Coffee Grinder Base Plate Replacement: step 2, image 2 of 3 Krups F203 Coffee Grinder Base Plate Replacement: step 2, image 3 of 3
    • Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Try not to break these clips as this will cause structural integrity issues upon reassembly
  3. Krups F203 Coffee Grinder Base Plate Replacement: step 3, image 1 of 2 Krups F203 Coffee Grinder Base Plate Replacement: step 3, image 2 of 2
    • Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
9 other people completed this guide.
Brian Wolfskill
420 Reputation
1 Guide authored
Baylor, Team 4-2, Williams Fall 2014 Member of Baylor, Team 4-2, Williams Fall 2014
BU-WILLIAMS-F14S4G2
3 Members
10 Guides authored
10 Comments
Thanks! I was able to repair my broken cord.
wdswaim - Reply
I'mworking on it as we write .
jerry - Reply
Does anyone have a video tutorial explaining how the heck one removes the base?? I bought a spudger and it still doesn't help. It is awfully hard to loosen up.. I kept trying and trying but I stopped cause I'm concerned I might break the clips and the outside which the plastic is starting to stretch.. the clips are starting to lose their shape as well and worried I might break the spudger... Thanks
NeonAera - Reply
I am having the same experience as NeonAera posted. I could clear 2 of the 4 clips, but not the others and getting the same issue of distorting the outside wall of the base , if I continue to try and pry the clips with the spudger. Thanks
Steve Ferrill - Reply
We had a jammed . I disassembled according to the guide, scraped out the rust I found, lubricated with WD40 and reassembled. Went from not moving to working great. I broke all 4 tabs (guess I lack patience…) but gorilla taped it back together and it's totally solid.
Wade Brainerd - Reply
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 49
All Time: 11,403
