Krups F203 Coffee Grinder Plug/Cord Replacement
  1. Krups F203 Coffee Grinder Plug/Cord Replacement, Base Plate: step 1, image 1 of 1
    • In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
  2. Krups F203 Coffee Grinder Plug/Cord Replacement: step 2, image 1 of 3 Krups F203 Coffee Grinder Plug/Cord Replacement: step 2, image 2 of 3 Krups F203 Coffee Grinder Plug/Cord Replacement: step 2, image 3 of 3
    • Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Try not to break these clips as this will cause structural integrity issues upon reassembly
  3. Krups F203 Coffee Grinder Plug/Cord Replacement: step 3, image 1 of 2 Krups F203 Coffee Grinder Plug/Cord Replacement: step 3, image 2 of 2
    • Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
  4. Krups F203 Coffee Grinder Plug/Cord Replacement, Detach Trigger Button from Base Plate: step 4, image 1 of 2 Krups F203 Coffee Grinder Plug/Cord Replacement, Detach Trigger Button from Base Plate: step 4, image 2 of 2
    • The trigger button is held in with light tension clips. Gently pry them back to release.
  5. Krups F203 Coffee Grinder Plug/Cord Replacement, Remove the wire from two contact points: step 5, image 1 of 1
    • Use the soldering iron to remove the existing solder.
    • Be sure to reference the how to solder video posted on the device page.
Ian Hancock
423 Reputation
3 Guides authored
Baylor, Team 4-2, Williams Fall 2014 Member of Baylor, Team 4-2, Williams Fall 2014
BU-WILLIAMS-F14S4G2
3 Members
10 Guides authored
One Comment
Thank you for posting this guide. Had to break the plastic "fingers" to remove the base.
Krups must have a special tool for this purpose.
Greg - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 40
All Time: 3,216
