Kyocera Hydro Life Charging Port Replacement
  1. Kyocera Hydro Life Charging Port Replacement, Charging Port: step 1, image 1 of 2 Kyocera Hydro Life Charging Port Replacement, Charging Port: step 1, image 2 of 2
    • Remove the back of the phone.
  2. Kyocera Hydro Life Charging Port Replacement: step 2, image 1 of 3 Kyocera Hydro Life Charging Port Replacement: step 2, image 2 of 3 Kyocera Hydro Life Charging Port Replacement: step 2, image 3 of 3
    • Remove the battery by pulling up on the end and towards yourself.
  3. Kyocera Hydro Life Charging Port Replacement: step 3, image 1 of 1
    • Use a PH0 screwdriver to remove the 6 screws which are holding the panel in the phone.
  4. Kyocera Hydro Life Charging Port Replacement: step 4, image 1 of 3 Kyocera Hydro Life Charging Port Replacement: step 4, image 2 of 3 Kyocera Hydro Life Charging Port Replacement: step 4, image 3 of 3
    • Remove the frame from around the back of the phone.
    • Then remove the back panel of the phone.
    • Remove the white sticker from in the middle of the phone.
  5. Kyocera Hydro Life Charging Port Replacement: step 5, image 1 of 3 Kyocera Hydro Life Charging Port Replacement: step 5, image 2 of 3 Kyocera Hydro Life Charging Port Replacement: step 5, image 3 of 3
    • Desolder the 7 pins.
    • If you have never soldered before, follow this guide.
    • This type of soldering requires very specialized and expensive equipment. Please be careful if you decide to continue following this guide.
  6. Kyocera Hydro Life Charging Port Replacement: step 6, image 1 of 2 Kyocera Hydro Life Charging Port Replacement: step 6, image 2 of 2
    • Desolder the positive and negative terminals.
  7. Kyocera Hydro Life Charging Port Replacement: step 7, image 1 of 1
    • Peel back the copper plated sticker.
    • If the copper plated sticker is broken, it must be replaced. If it is not broken during disassembly, it can be reused.
  8. Kyocera Hydro Life Charging Port Replacement: step 8, image 1 of 1
    • Remove the motherboard without breaking it by placing it to the side. It will still be attached to the phone.
  9. Kyocera Hydro Life Charging Port Replacement: step 9, image 1 of 1
    • Using force, remove the charging port from the charging slot.
  10. Kyocera Hydro Life Charging Port Replacement: step 10, image 1 of 1
    • Replace the charging port and ribbon.
    • If the copper-plated sticker is damaged, it will need to be replaced as well.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 1,022
