Kyocera Hydro Life Power Button Replacement
  1. Kyocera Hydro Life Power Button Replacement, Power Button: step 1, image 1 of 1
    • Remove the back cover.
    • Pry the cover upward from the gap above the charger port as displayed.
  2. Kyocera Hydro Life Power Button Replacement: step 2, image 1 of 1
    • Remove the battery.
  3. Kyocera Hydro Life Power Button Replacement: step 3, image 1 of 2 Kyocera Hydro Life Power Button Replacement: step 3, image 2 of 2
    • Use a PH00 screwdriver to remove the 6 screws from the mid-frame.
    • Removing the screws too carelessly can result in them being damaged or stripped.
  4. Kyocera Hydro Life Power Button Replacement: step 4, image 1 of 1
    • Remove the back panel trim.
    • The back panel trim is fairly thin, be cautious when removing it.
  5. Kyocera Hydro Life Power Button Replacement: step 5, image 1 of 1
    • Remove the back panel.
    • Pry off the 4 corners first.
  6. Kyocera Hydro Life Power Button Replacement: step 6, image 1 of 2 Kyocera Hydro Life Power Button Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the power button with the tweezers.
Haley Brown
183 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 39
All Time: 381
