Kyocera Hydro Vibe SIM Card Replacement
  1. Kyocera Hydro Vibe SIM Card Replacement, Battery: step 1, image 1 of 1
    • Make sure that the device is turned off before beginning.
    • Look for a small indentation on the bottom of the phone.
    • Insert the plastic opening tool into the indentation and lift off the back casing.
  2. Kyocera Hydro Vibe SIM Card Replacement: step 2, image 1 of 3 Kyocera Hydro Vibe SIM Card Replacement: step 2, image 2 of 3 Kyocera Hydro Vibe SIM Card Replacement: step 2, image 3 of 3
    • The large white component is the battery. Look for a small indentation under the arrow that says "LIFT."
    • Place the plastic opening tool in the indentation and lift the battery out of the socket.
  3. Kyocera Hydro Vibe SIM Card Replacement, SIM Card: step 3, image 1 of 1
    • Locate the SIM card indicated by the arrows and picture.
  4. Kyocera Hydro Vibe SIM Card Replacement: step 4, image 1 of 2 Kyocera Hydro Vibe SIM Card Replacement: step 4, image 2 of 2
    • Use the precision tweezer set to safely remove the SIM card.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 650
