Kyocera Opal S14 Rear Case Replacement
  1. Kyocera Opal S14 Rear Case Replacement, Rear Case: step 1, image 1 of 2 Kyocera Opal S14 Rear Case Replacement, Rear Case: step 1, image 2 of 2
    • Wedge the opening device into the side crease of the phone.
  2. Kyocera Opal S14 Rear Case Replacement: step 2, image 1 of 2 Kyocera Opal S14 Rear Case Replacement: step 2, image 2 of 2
    • Slide the opening device downward to dis-join the rear casing from the front casing. Continue around all edges.
  3. Kyocera Opal S14 Rear Case Replacement: step 3, image 1 of 1
    • Remove the back casing from the front casing. Force may be necessary.
Erica
101 Reputation
3 Guides authored
James Madison, Team 1-49, Allen Fall 2011 Member of James Madison, Team 1-49, Allen Fall 2011
JMU-ALLEN-F11S1G49
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 745
