Kyocera QCP-2035 Battery Replacement
  1. Kyocera QCP-2035 Battery Replacement, Removing Back Cover: step 1, image 1 of 3 Kyocera QCP-2035 Battery Replacement, Removing Back Cover: step 1, image 2 of 3 Kyocera QCP-2035 Battery Replacement, Removing Back Cover: step 1, image 3 of 3
    • When looking at the back of the phone, you will see a horizontal line and three raised segments of plastic in the form of a triangle.
    • Place thumb on top of the triangle and press into the phone while sliding your thumb towards the bottom of the phone.
    • In 5 mm it will stop sliding.
  2. Kyocera QCP-2035 Battery Replacement: step 2, image 1 of 2 Kyocera QCP-2035 Battery Replacement: step 2, image 2 of 2
    • Grab the bottom of the back cover with your other hand and pull the cover the rest of the way off.
    • Turn the phone over slowly. The battery will fall out on its own.
Scott Whitney
301 Reputation
3 Guides authored
USF Tampa, Team 5-3, Brown Winter 2015 Member of USF Tampa, Team 5-3, Brown Winter 2015
USFT-BROWN-W15S5G3
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 236
