LCD LG 37LF65 Capacitor replacement
  1. LCD LG 37LF65 Capacitor replacement, Open the case: step 1, image 1 of 1
    • Power off and unplug your device before starting this repair.
    • Open the case carefully while loosing the marked srews.
  2. LCD LG 37LF65 Capacitor replacement, Replace the capacitors: step 2, image 1 of 1
    • Check the power-board. If there are any blown-up capacitors, you should replace them.
    • For removing the capacitors, remove the board, take a soldering bolt and heat the solder points at the back of the board.
    • Insert the replacement capacitors and solder it. Check the poles!
  3. LCD LG 37LF65 Capacitor replacement, Testing capacitors: step 3, image 1 of 1
    • If you are not sure about the condition of the capacitors you can prove it with a good measuring device after the expansion.
Not all capacitors are need in any case. To reassemble your device, follow these instructions in reverse order.
10 other people completed this guide.
eugl18
582 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 65
All Time: 14,358
