LCD Replacement
  1. LCD Replacement, Rear Cover: step 1, image 1 of 1
    • First ensure your laptop is turned off and check if you have the necessary tools
  2. LCD Replacement: step 2, image 1 of 2 LCD Replacement: step 2, image 2 of 2
    • All screws are identified by circles. Pay special attention to the yellow circles, as the rubber feet hide screws.
  3. LCD Replacement: step 3, image 1 of 3 LCD Replacement: step 3, image 2 of 3 LCD Replacement: step 3, image 3 of 3
    • With the opening tool, remove a rubber foot.
    • For this action you will have to exert some force, because the foot is glued with a resistant glue.
  4. LCD Replacement: step 4, image 1 of 1
    • Remove all screws with a Philips screwdriver PH1
    • All screws are the same so don't worry about identifying them.
  5. LCD Replacement: step 5, image 1 of 3 LCD Replacement: step 5, image 2 of 3 LCD Replacement: step 5, image 3 of 3
    • With the plastic tool, insert between the plastics and gently pry open.
    • With your fingers continue to force open the bottom cover on the side indicated in the figure.
    • You will feel and hear several clicks, perfectly normal, nothing is breaking. Remove the cover completely.
  6. LCD Replacement: step 6, image 1 of 1
    • Finally, we have the laptop open and ready to replace most of its components. Look elsewhere on how to replace a component.
    • To close the laptop just follow this guide in reverse.
    • Insert instructions here.
To reassemble your device, follow the previous steps in inverse order.
Special thanks to these translators:
pt en
100%
David is helping us fix the world! Want to contribute?
Start translating ›
Nelson Oliveira
741 Reputation
4 Guides authored
jp.ik Member of jp.ik
Business
2 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 39
