LCD X2gen Display disassembly
  1. LCD X2gen Display disassembly, Display: step 1, image 1 of 1
    • X2gen 22 lcd Screen repair guide
  2. LCD X2gen Display disassembly: step 2, image 1 of 1
    • Power board displaying the capacitors to be replaced
  3. LCD X2gen Display disassembly: step 3, image 1 of 1
    • Display viewed laying face down on the working table (my dining table)
    • Remove the 6 screws. 4 on the corners and 2 middle bottom.
  4. LCD X2gen Display disassembly: step 4, image 1 of 1
    • Remove front bezel by lifting softly starting from the middle and moving out to the corners.
  5. LCD X2gen Display disassembly: step 5, image 1 of 1
    • Top middle
  6. LCD X2gen Display disassembly: step 6, image 1 of 1
    • Front bezel removed.
    • Observe: the control board, bottom right.
    • exposed screws on both sides (4 left, 4 right) holding the LCD to the back cover.
  7. LCD X2gen Display disassembly: step 7, image 1 of 1
    • Prepare to remove the 4 screws on each side to lift the LCD. Do not try to remove it after unscrewing the 8 screws. There are cables connected on the back.
    • This pic shows the right side
  8. LCD X2gen Display disassembly: step 8, image 1 of 1
    • This pic shows the left side
  9. LCD X2gen Display disassembly: step 9, image 1 of 2 LCD X2gen Display disassembly: step 9, image 2 of 2
    • Lift carefully about 2 inch to expose the back light connections, 2 pink and 2 white.
    • Slide the monitor to the left about 3-4 inch. to have access to the connections.
  10. LCD X2gen Display disassembly: step 10, image 1 of 1
    • Carefully, unplug both connectors
  11. LCD X2gen Display disassembly: step 11, image 1 of 2 LCD X2gen Display disassembly: step 11, image 2 of 2
    • After removing the connectors, slide it about 3-5 inches to the right to have access to the data connector and ground
  12. LCD X2gen Display disassembly: step 12, image 1 of 1
    • Remove the data connector and ground.
    • Lift display. Is now completely free
2 other people completed this guide.
Aleks
201 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 56
All Time: 2,050
