LERSTA Floor Lamp Screw Terminal Replacement
  1. LERSTA Floor Lamp Screw Terminal Replacement, Screw Terminal: step 1, image 1 of 2 LERSTA Floor Lamp Screw Terminal Replacement, Screw Terminal: step 1, image 2 of 2
    • Unplug the lamp.
  2. LERSTA Floor Lamp Screw Terminal Replacement: step 2, image 1 of 1
    • Rotate the bulb counterclockwise to remove the light bulb.
  3. LERSTA Floor Lamp Screw Terminal Replacement: step 3, image 1 of 1
    • Rotate the lamp shade counterclockwise.
  4. LERSTA Floor Lamp Screw Terminal Replacement: step 4, image 1 of 1
    • Take the three parts aside after dismantling the lamp shade.
  5. LERSTA Floor Lamp Screw Terminal Replacement: step 5, image 1 of 1
    • Dismantle the lamp shaft by rotating it counterclockwise.
  6. LERSTA Floor Lamp Screw Terminal Replacement: step 6, image 1 of 1
    • Use a Phillips screwdriver to remove the two 3 mm screws from the silver cover.
    • Pull down both the silver cover and the black screw terminal.
  7. LERSTA Floor Lamp Screw Terminal Replacement: step 7, image 1 of 1
    • Separate the light bulb socket from the silver cover by pulling the silver metal hasp in right-downward direction towards the lamp shaft.
    • Exert force on the both left and right hand sides of the hasp and then pull the hasp downward.
  8. LERSTA Floor Lamp Screw Terminal Replacement: step 8, image 1 of 1
    • Replace the old bulb socket with a newly-purchased one.
Replacing the screw terminal of the floor lamp is relatively easy, but be cautious to deal with the step of the substitution of the light socket.
[deleted]
157 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 998
