LG 305C Speaker Replacement
  1. LG 305C Speaker Replacement, Battery: step 1, image 1 of 1
    • Pry open the back case on the device with a plastic opening tool and remove it.
  2. LG 305C Speaker Replacement: step 2, image 1 of 1
    • Pry the battery out of the device with a plastic opening tool and remove it.
  3. LG 305C Speaker Replacement, Internal Casing: step 3, image 1 of 1
    • Remove the three 4 mm screws using a JIS screwdriver with a J000 head from the bottom part of the internal casing.
  4. LG 305C Speaker Replacement: step 4, image 1 of 1
    • Pry open the bottom part of the internal casing with the plastic opening tool and remove it.
  5. LG 305C Speaker Replacement: step 5, image 1 of 1
    • Remove the four 4 mm screws using a JIS screwdriver with a J000 head from the top part of the internal casing.
  6. LG 305C Speaker Replacement: step 6, image 1 of 1
    • Pry open the top part of the internal casing with the plastic opening tool and remove it.
  7. LG 305C Speaker Replacement, Speaker: step 7, image 1 of 1
    • Insert plastic opening tool under the plastic flap and lift the speaker out.
Joaquin Garcia
73 Reputation
1 Guide authored
IUPUI, Team S6-G1, Baechle Spring 2018 Member of IUPUI, Team S6-G1, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G1
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 129
