Introduction
If the front of your phone is damaged it may not display the images properly.
In order to begin replacing your screen, you should first power down your device and remove the battery.
Take a very thin plastic/ metal prying tool and gently work your way around the phone. You should hear popping sounds as each lock is opened. Be very careful as you pry open the case as you could damage the LCD/Motherboard.
Take your new screen and place it onto the front of the phone. Very gently apply pressure until you here the locks click into place.
