LG Aristo MS210 Command Button Replacement
  1. LG Aristo MS210 Command Button Replacement, Battery: step 1, image 1 of 3 LG Aristo MS210 Command Button Replacement, Battery: step 1, image 2 of 3 LG Aristo MS210 Command Button Replacement, Battery: step 1, image 3 of 3
    • Insert the spudger into the notch on the bottom left side of the phone.
    • Apply light pressure to remove the back cover.
  2. LG Aristo MS210 Command Button Replacement: step 2, image 1 of 2 LG Aristo MS210 Command Button Replacement: step 2, image 2 of 2
    • Insert the spudger into the notch located on the bottom middle of the battery.
    • Apply light pressure to remove the battery.
  3. LG Aristo MS210 Command Button Replacement, Command Button: step 3, image 1 of 3 LG Aristo MS210 Command Button Replacement, Command Button: step 3, image 2 of 3 LG Aristo MS210 Command Button Replacement, Command Button: step 3, image 3 of 3
    • Use the PH000 bit unscrew the ten 3.4mm screws as highlighted.
    • Use the spudger to remove the inner shell.
    • Flip the inner shell over to expose the clips holding the command button.
  4. LG Aristo MS210 Command Button Replacement: step 4, image 1 of 3 LG Aristo MS210 Command Button Replacement: step 4, image 2 of 3 LG Aristo MS210 Command Button Replacement: step 4, image 3 of 3
    • Use the spudger disconnect the three clips holding in the command button as highlighted.
    • Remove the command button.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 321
