LG BP220 Disc Drive Replacement
  1. LG BP220 Disc Drive Replacement, Disc Drive: step 1, image 1 of 2 LG BP220 Disc Drive Replacement, Disc Drive: step 1, image 2 of 2
    • Ensure the device is unplugged to prevent shocks.
    • Remove the three black 3/16” Phillips #2 screws from the backside of the player.
    • With the backside (audio/video jacks) facing you, lift the part of the cover closer to you and pull until it is off.
  2. LG BP220 Disc Drive Replacement: step 2, image 1 of 1
    • Using your fingers, pull the three tape-like cables to disconnect the disc drive from the green motherboard.
  3. LG BP220 Disc Drive Replacement: step 3, image 1 of 3 LG BP220 Disc Drive Replacement: step 3, image 2 of 3 LG BP220 Disc Drive Replacement: step 3, image 3 of 3
    • Unhinge the tabs that attach the front panel to the unit:
    • Two tabs on the disc drive
    • Two tabs on the left and right side of the player
    • Be careful when handling these tabs. They are very fragile and can be easily broken.
    • Three tabs on the underside of the player
    • Pull panel away from case.
    • If the panel does not come off right away, be sure to check if tabs have inadvertently switched back to their locked position.
  4. LG BP220 Disc Drive Replacement: step 4, image 1 of 2 LG BP220 Disc Drive Replacement: step 4, image 2 of 2
    • Remove the two black 3/16” Phillips #2 mounting screws from the left and right side of the disc drive.
    • With the front side facing you lift the front of disc drive and pull out to remove.
6 other people completed this guide.
Bart Quicho
502 Reputation
3 Guides authored
UW Tacoma, Team 1-1, Rose Winter 2015 Member of UW Tacoma, Team 1-1, Rose Winter 2015
UWT-ROSE-W15S1G1
4 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 59
All Time: 9,160
