LG CF360 Rear Speaker Replacement
  1. LG CF360 Rear Speaker Replacement, Battery: step 1, image 1 of 2 LG CF360 Rear Speaker Replacement, Battery: step 1, image 2 of 2
    • On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
  2. LG CF360 Rear Speaker Replacement: step 2, image 1 of 1
    • Lift and remove the battery.
  3. LG CF360 Rear Speaker Replacement, Back Cover: step 3, image 1 of 2 LG CF360 Rear Speaker Replacement, Back Cover: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the two screw covers at the top of phone with tweezers.
  4. LG CF360 Rear Speaker Replacement: step 4, image 1 of 1
    • Remove the six Phillips #000 (3mm) screws.
  5. LG CF360 Rear Speaker Replacement: step 5, image 1 of 3 LG CF360 Rear Speaker Replacement: step 5, image 2 of 3 LG CF360 Rear Speaker Replacement: step 5, image 3 of 3
    • Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone.
    • The plastic side buttons fall out when you take the back cover off.
    • The back cover is connected to the speaker by red and black wires.
  6. LG CF360 Rear Speaker Replacement: step 6, image 1 of 1
    • Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
    • Set the back cover with the speaker aside.
  7. LG CF360 Rear Speaker Replacement, Rear Speaker: step 7, image 1 of 1
    • Use the plastic opening tool to pry the speaker cover off of the phone.
  8. LG CF360 Rear Speaker Replacement: step 8, image 1 of 1
    • Use the plastic opening tool to pry the speaker out of the back cover.
Annie White
262 Reputation
2 Guides authored
Cal Poly, Team 4-27, Amido Fall 2013 Member of Cal Poly, Team 4-27, Amido Fall 2013
CPSU-AMIDO-F13S4G27
4 Members
19 Guides authored
One Comment
Where can I buy the replacement parts?
Sarah Birkett - Reply
Past 24 Hours: 4
Past 7 Days: 5
Past 30 Days: 16
All Time: 350
