LG CG180 Keypad Replacement
  1. LG CG180 Keypad Replacement, Battery: step 1, image 1 of 1
    • Power down the cell phone by pressing and holding down the red "end call" button.
  2. LG CG180 Keypad Replacement: step 2, image 1 of 1
    • Turn the phone screen-down so you are looking at the back cover.
  3. LG CG180 Keypad Replacement: step 3, image 1 of 2 LG CG180 Keypad Replacement: step 3, image 2 of 2
    • Slide the back cover down using your finger to remove the cover from the phone.
  4. LG CG180 Keypad Replacement: step 4, image 1 of 1
    • Place your finger at the top of the battery in small gap.
  5. LG CG180 Keypad Replacement: step 5, image 1 of 1
    • Press downward while pulling outward to remove the battery.
  6. LG CG180 Keypad Replacement, Hardshell Case: step 6, image 1 of 1
    • Remove all four screws on the back of the phone using a Phillips #00 screwdriver.
  7. LG CG180 Keypad Replacement: step 7, image 1 of 1
    • Insert a plastic opening tool in the seam.
  8. LG CG180 Keypad Replacement: step 8, image 1 of 2 LG CG180 Keypad Replacement: step 8, image 2 of 2
    • Run the tool along the seam to release all the tabs.
  9. LG CG180 Keypad Replacement: step 9, image 1 of 2 LG CG180 Keypad Replacement: step 9, image 2 of 2
    • Pull the phone back cover off once all the tabs are released.
  10. LG CG180 Keypad Replacement: step 10, image 1 of 1
    • Push the contents of the phone away from the hardshell case by applying pressure to the keypad with both thumbs.
  11. LG CG180 Keypad Replacement: step 11, image 1 of 1
    • The hardshell case is separated from the rest of the phone.
  12. LG CG180 Keypad Replacement, Keypad: step 12, image 1 of 2 LG CG180 Keypad Replacement, Keypad: step 12, image 2 of 2
    • Separate keypad from circuit board by turning it upside down and allowing it to fall off.
Alex Jacobs
5 Reputation
4 Guides authored
Cal Poly, Team 14-42, Regan Winter 2010 Member of Cal Poly, Team 14-42, Regan Winter 2010
CPSU-REGAN-W10S14G42
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 1,459
