LG CG225 Keyboard Replacement
  1. LG CG225 Keyboard Replacement, Rear Cover: step 1, image 1 of 1
    • Using a spudger or plastic opening tool, pry off the screw cover near the phone's antenna.
  2. LG CG225 Keyboard Replacement: step 2, image 1 of 1
    • Remove a single Phillips #00 screw from beneath the cover.
  3. LG CG225 Keyboard Replacement: step 3, image 1 of 1
    • Starting at the seam near the antenna, use a plastic opening tool to gently pry the back plate from the phone.
  4. LG CG225 Keyboard Replacement, Motherboard: step 4, image 1 of 1
    • Carefully disconnect the gold ribbon cable from the upper right corner of the motherboard.
  5. LG CG225 Keyboard Replacement: step 5, image 1 of 1
    • Using a small plastic opening tool, remove the motherboard.
  6. LG CG225 Keyboard Replacement, Keyboard: step 6, image 1 of 1
    • Using your fingers, remove the plastic keyboard.
    • Loose buttons will sometimes fall off of the keyboard when it is removed.
Mackenzie
1 Reputation
2 Guides authored
Ohio State, Team 1-3, Meza Spring 2014 Member of Ohio State, Team 1-3, Meza Spring 2014
OSU-MEZA-S14S1G3
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 350
