LG CU515 Keypad Replacement
  1. LG CU515 Keypad Replacement, Battery: step 1, image 1 of 2 LG CU515 Keypad Replacement, Battery: step 1, image 2 of 2
    • Use your thumb to press down and slide off the back cover of the phone.
  2. LG CU515 Keypad Replacement: step 2, image 1 of 3 LG CU515 Keypad Replacement: step 2, image 2 of 3 LG CU515 Keypad Replacement: step 2, image 3 of 3
    • Take out the battery by levering it out towards the bottom of the phone.
  3. LG CU515 Keypad Replacement, Motherboard: step 3, image 1 of 1
    • Push the spudger between each of the two rubber cushions and the body of the phone. Then turn the spudger to pop each cushion out.
  4. LG CU515 Keypad Replacement: step 4, image 1 of 1
    • Remove six 3.0 mm Phillips #00 screws from the back of the phone.
  5. LG CU515 Keypad Replacement: step 5, image 1 of 3 LG CU515 Keypad Replacement: step 5, image 2 of 3 LG CU515 Keypad Replacement: step 5, image 3 of 3
    • Push the spudger into the crack separating the two pieces of the phone.
    • Then use the plastic opening tools to pry the back off by separating the two pieces of the phone.
    • Repeat as necessary around the perimeter of the phone until the casing pops off. Use force as necessary without breaking the cover.
    • The back is attached to the motherboard by a wire, so don't pull the back casing off just yet.
  6. LG CU515 Keypad Replacement: step 6, image 1 of 1
    • Gently pull the wire up from the motherboard, separating the back of the phone and the motherboard.
  7. LG CU515 Keypad Replacement: step 7, image 1 of 1
    • Remove the plastic tab connecting the screen to the motherboard by pulling the tab up from the board.
  8. LG CU515 Keypad Replacement: step 8, image 1 of 1
    • Gently grasp one of the corners of the motherboard and simply lift it straight up out of the phone casing.
    • Replace the motherboard with a new one.
  9. LG CU515 Keypad Replacement, Keypad: step 9, image 1 of 1
    • Push keypad up and out of the phone casing until they separate.
    • Replace with new keypad.
Zack Mintzer
1 Reputation
6 Guides authored
Cal Poly, Team 21-55, Johann Spring 2013 Member of Cal Poly, Team 21-55, Johann Spring 2013
CPSU-JOHANN-S13S21G55
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 302
