LG Chocolate 3 Rear Case Replacement
  1. LG Chocolate 3 Rear Case Replacement, Battery: step 1, image 1 of 1
    • Turn the phone off before starting the replacement process.
    • Place the phone face down.
    • Press your finger down on the indentation and slide the back plate off.
  2. LG Chocolate 3 Rear Case Replacement: step 2, image 1 of 3 LG Chocolate 3 Rear Case Replacement: step 2, image 2 of 3 LG Chocolate 3 Rear Case Replacement: step 2, image 3 of 3
    • Using your index finger lift and remove the battery from the phone.
  3. LG Chocolate 3 Rear Case Replacement, Rear Case: step 3, image 1 of 1
    • Use the pointed end of the spudger to pull out the plastic inserts that are located on the left and right-hand corners.
    • If needed, use the tip of a push pin instead of the spudger to remove the plastic inserts.
  4. LG Chocolate 3 Rear Case Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Using a Phillips #00 screwdriver, remove the six 3mm long screws found along the edges of the phone.
    • If needed, use tweezers to remove loose screws from the recessed holes.
    • Screws are small, therefore, they should be placed in a secure location to prevent misplacement.
  5. LG Chocolate 3 Rear Case Replacement: step 5, image 1 of 2 LG Chocolate 3 Rear Case Replacement: step 5, image 2 of 2
    • Pull the rear case up using the spudger.
    • The rear case is connected to the right side of the phone via red and blue cables, be careful not to pull these cables out.
    • The volume control buttons on the side might fall out of their sockets. Carefully replace them with a pair of tweezers before you reassemble the rear case.
  6. LG Chocolate 3 Rear Case Replacement: step 6, image 1 of 1
    • Use tweezers to pull the clear end of the red and blue speaker cables away from motherboard.
  7. LG Chocolate 3 Rear Case Replacement: step 7, image 1 of 2 LG Chocolate 3 Rear Case Replacement: step 7, image 2 of 2
    • Carefully remove the rear case from the phone.
Brenna Yagade
40 Reputation
6 Guides authored
Cal Poly, Team 12-35, Amido Spring 2013 Member of Cal Poly, Team 12-35, Amido Spring 2013
CPSU-AMIDO-S13S12G35
5 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 308
